12 years agoHow generate signal DCLK?
Hi, When the FPGA is power on and the FPGA does not have any internal configuration. Is generated automatic the signal DCLK, to load a configuration from an EPCS? Must I generate it wi...
12 years agoReview the device handbook about AS (active serial) configuration scheme and the meaning of each involved signal. No external signals are required,
