17 years agoHow do write DATA into RAM and Internal Memory in Flex10K
Dear all,
I am in the middle of a project and have come across a glitch at the moment. One of the core aspects of this project is to write the data received from encoders or LCD to the internal memory provided within the FLEX10K. I have been searching and have found that the FLEX10 has 2KB of memory. In the FLEX10K there are 8 EAB's each with a capacity of 2048 bits. How can I write to a specific spot in memory. From my understanding, each one of those bits in the EAB should have an address associated with it. My question is how do I decide which address I can write to and how do I do that in VHDL. From my research I came across people using *.mif and *.hex files but I do not see how it can be used since it does not provide an address. I also saw the Megawizard Plug-In manager for several RAM and ROM schematics but I still am not sure how to implement it on the FLEX10K. I appreciate all kinds of help. Cheers1 Reply
Hi Ali,
You need to instantiate a block of ram of suitable size/width then control its interface(address,data,ctrl signals). you can then read/write to the block. Thats all. mif files are meant for initialisation only, not needed in your case kaz
