12 years agoHow do I use the ALTLVDS_RX megafunction with 12-bit
Hi, I am trying to connect 4 channel 12 bit LVDS ADC to Cyclone V, the megafunction ALTLVDS_RX support only 10 deserialization factor, this link (http://altera.info/support/kdb/solutions/rd071...
11 years agoHi,
I'm having the same problem. I have a serial datastream of 12 bit or each value. I need to make it parallel. Altera says use ALTLVDS_RX with des-factor of 6 and do it two times. But how? Regards. --- Quote Start --- I made some progress, but I am stuck with a strange error in Quartus! whenever I connect the final output of LVDS signal to NIOS II, I got an error message No. 129001.......the strange thing is, if I removed the connection to NIOS II, this error disappear and the compilation finished successfully. Please have a look to the attached picture for more details. an advice is highly appreciated. --- Quote End ---
