12 years agoHow do I synchronize gray code counts safely across asynchronous clock domains?
I have a design for a generic asynchronous FIFO that I have used for many years. In this FIFO, I use gray code counters for the read and write pointers to the core memory. These multi-bit pointers mu...
11 years agoSorry for my poor English, I'm from China
I found something strange:in the 《SCFIFO and DCFIFO IP Cores User Guide》,which is the altera megacore fifo user guide,it says that “ When using the Quartus II TimeQuest timing analyzer with a design that contains a DCFIFO block apply the following false paths to avoid timing failures in the synchronization registers: •For paths crossing from the write into the read domain, apply a false path assignment between the delayed_wrptr_g and rs_dgwp registers: set_false_path -from [get_registers {*dcfifo*delayed_wrptr_g [*]}] -to [get_registers {*dcfifo*rs_dgwp*}] •For paths crossing from the read into the write domain, apply a false path assignment between the rdptr_g and ws_dgrp registers: set_false_path -from [get_registers {*dcfifo*rdptr_g [*]}] -to [get_registers {*dcfifo*ws_dgrp*}] The false path assignments are automatically added through the HDL-embedded Synopsis design constraint (SDC) commands when you compile your design. The related message is shown under the TimeQuest timing analyzer report. Note: The constraints are internally applied but are not written to the Synopsis Design Constraint File (.sdc). To view the embedded-false path, type report_sdc in the console pane of the TimeQuest timing analyzer GUI. ” To my knowledge, the gray code of pointer in the fifo should use the set_max_delay to avoid the ptr delay exceed 1 clk cycle of fastest clk. It should not use the set_false_path constrain to the dcfifo I don't know why. When I generate the async fifo in the vivado of xilinx , I can find that the tool generate the set_max_delay constrain in the XDC file. I was confused
