10 years agoHow do I setup word sychronisation with Altera Soft LVDS with external PLL on MAX10
Hi, I successfully setup a SerDes link between two MAX10 devices with the soft LVDS IP and internal (!) PLL. The devices are connected by two LVDS signals - one for clock and one for data. ...
10 years agoSearch around for "altlvds align" and you'll find several threads here and elsewhere talking about the issue of aligning data coming out of the ALTLVDS_RX.
Long story short, you feed the RX path a known pattern and jog the 'align' bit to shift the word until it matches the pattern you expect. In your case, you probably want to supply ALTLVDS_RX with your 10MHz clock as an additional 'rx_in' to key off as a framing signal.
