WShep1
Contributor
7 years agoHow do I find out what the SBT for NIOS error "Downloading ELF Process Failed"?
I am working on a NIOS project that currently has a very simple NIOS program running on a Platform Designer Qsys system. I made a change to the Qsys system, generated the HDL for the Qsys system,...
Jens
7 years agoIt seems to me that on the board another system is running than you want to debug. (Are the LEDs connected to Nios2? So clock and reset work)
Check in the Nios2 IDE the BSP project location in the Nios2 application project properties.
How do you create the bin files for FPGA configuration and Nios2 program and where are they stored on the board? Is it possible that you have programmed a different version?
Jens
