WShep1
Contributor
7 years agoHow do I find out what the SBT for NIOS error "Downloading ELF Process Failed"?
I am working on a NIOS project that currently has a very simple NIOS program running on a Platform Designer Qsys system. I made a change to the Qsys system, generated the HDL for the Qsys system,...
FawazJ_Altera
7 years agoHello,
This is a generic elf download failure message. Probably there should be a console message that clarifies where is the source of failure.
It might be:
1- Nios II FAILED to response
(In this case, there would be an issue with Nios II clock or reset).
2- Failure in address between xxxx to yyyy,
(This means there is an IP (mostly external memory), that fails to respond)
