Linshen_liu
3 years agoHow code a cyclone 10 GX board in order to made it as a large current load
I need to use a cyclone 10 GX work as an E-load, that means a load curent change with high slew rate, what should I do to design a such that system on that board.
Farabi_Altera
3 years agoHello,
current e-load circuitry require a power(analog) electronic components. You can't use FPGA to implement current e-load circuit.
regards,
Farabi
Linshen_liu
3 years agoHello,
Thank you to point out my error. Because I am in a Power Electronic research group, we have built some DC-DC converter and LDO before. What we plan to do is to connect the component we built before with FPGA core. The FPGA core only need to consum the Power from the DC-DC converter we built before, but I have no idea how to code the FPGA. I guess it might work sense in hardware.
It is my plaesure to see your reply~
Best regards
Linshen Liu
