Yakov_E
2 years agoHow Change I2C clock on Cyclone V HPS , Terasic DE10-Nano
We use Terasic DE10-NANO with Linux Console (kernel 4.5), copied from DE10-Nano Kit . It works fine. We recently started using LTC I2C interface for our I2C device with no success. After some inve...
- 2 years ago
Hi Tiwari
Thank you for the help
Link that you send me, HOWTO Create a Devicetree for Cyclone V SoC, is good, but our team found a way to do that much more simpler and faster. I described all the details in attached Word document and also other files for reference.
Note: attatched .dts file ise renamed to .dts.txt to be attached here
Bast Regards,
Yakov
Jeet14
2 years agoHi,
You can follow below link on HOWTO Create a Devicetree for Cyclone V SoC.
This will help to config I2C device node.
Tiwari
