How can I read button presses through the Avalon bus?
I have been trying to create a simple Avalon-MM Master to read from a PIO slave (push buttons), however I am reading only 0's on the readdata line.
Relevant code:
wire [31:0] master_0_master_address;
wire master_0_master_read;
wire [31:0] master_0_master_readdata;
reg [1:0]currentState;
reg [1:0]nextState;
reg [31:0] data;
reg [31:0] address;
reg read;
assign master_0_master_address = address;
assign master_0_master_read = read;
assign led11[3:0] = ((reset_reset_n == 0)) ? 4'b1111 : (data[3:0]);
always @ (*) begin
if(~reset_reset_n)
begin
data <= 32'b0;
nextState <= 2'b0;
end
else begin
case (currentState)
2'b0: begin
address <= 32'b100000;
read <= 1;
if(master_0_master_waitrequest)
nextState <= 2'b10;
else
nextState <= 2'b1;
end
2'b1: begin
read <= 0;
data <= master_0_master_readdata;
nextState <= 2'b0;
end
2'b10: begin
nextState <= 2'b10;
else
nextState <= 2'b1;
end
endcase
end
end
always @ (posedge clk_clk or negedge reset_reset_n)
begin
if(~reset_reset_n)
currentState <= 0;
else
currentState <= nextState;
endAnd the Qsys system:
- sstrell
I'm guessing that the signal names preceded by "master_" are your interface signals because I don't see a port list for your component. Is that correct?
Have you tried just leaving read enabled all the time and just do reads on waitrequest going low?
#iwork4intel
- Gabe
Yes, the signals preceded by "master_" are my interface signals. I have somehow managed to get it working. However, I have noticed some weird behavior: No matter the address I place on the master_0_address line, the state machine reads the pushbuttons' data register just fine. But if I add another PIO slave (LEDs) to the project, assign addresses, and then generate the files, then my code does not work anymore - I get 0's again. Seems like the issue is with slave addressing.
When I add the second PIO slave, Qsys assigns 0x0000_0000 to the pushbuttons, and 0x0000_0010 to the LEDs. To read from the pushbuttons' data register, I do master_0_address <= 32'b0. I am not sure if I need to add an offset to the address shown in Qsys or.. According to this document, the data register comes first, so there is a 0 offset to the address shown in Qsys.
Thanks for your help.
