13 years agohow can i check the chip i bought is fake or not
hi all:
I bought some fpga chips (ep3c16) on the web. but they are different with chips that i used.so i want to check the chips is fake or not.https://www.alteraforum.com/forum/attachment.php?attachmentid=6907 up:new;down:used6 Replies
--- Quote Start --- If it is fake, wont it take longer? --- Quote End --- this is not the first time i bought chips on this seller. orther chips are ok. only this ep3c16 have different marking form used. so a ...... i want to ask wether someone meet the marking like the picture i upload. if i am the only person meet this marking. it is really suspicious. - Altera_Forum
--- Quote Start --- i know that, but there is no time. --- Quote End --- If it is fake, wont it take longer? - Altera_Forum
You could check continuity between pins that should be connected internally, such as ground and supply pins. That should indicate if the chips were something else that has been remarked.
There can be slight differences in the markings when the chips are made in different factories, but the picture on the top really look suspicious. The triangles in the As aren't aligned properly, I think they are fake. Personally I wouldn't use them.
--- Quote Start --- best way - buy from an authorised dealer. --- Quote End --- i know that, but there is no time. - Altera_Forum
