11 years agoHow (and where) can I set the base address name of my slave component?!
Maybe it is a beginner question but I can not find any place where I can set the base address name for my slave component which uses a SPI interface. The SPI command in the main.c of the NIOS syst...
11 years agoIn Qsys, in the main 'System Contents' tab, right-click on your 'spi_0' peripheral and select 'Rename'. This allows you to change the 'SPI_0' part of the name.
The '_BASE' is appended to the name you give. So, you can't change it. However, if you don't like it I'd suggest you can always define a name you prefer that always equals the 'YOUR_NAME_BASE' value Qsys generates. All the define's Qsys creates for your project can be found in the 'system.h' file, created each time you 'Generate HDL' from Qsys. Cheers, Alex
