16 years ago
$hold violation in modelsim
Dear Sir,
While simulating with modelsim, I am getting the following error
** Error: E:/2K10 projects/ROP Glue Logic/ROP-Verilog-Quartus/VER4-files/simulation/modelsim/max_atoms.v(2125): $hold( posedge pclk[0] &&& reset:1416500 ps, datain:1417500 ps, 3 ns );# Time: 1417500 ps Iteration: 0 Instance: /tb_rop/UUT/\U1|U4|TMP[7] /preg
Using MAX7256SRI208-10 device. STA does not give any timing violation. But when running the testbench, I am finding many such $hold violation errors.
You may please note that "UUT/\U1|U4|TMP[7] /preg" is referring to a Serial in parallel our shift register.
I am not understanding as how to solve this problem. Amazingly, when I fuse this in target, it is working fine.
I need your help in pin pointing the exact problem in the above error message and what approach I have to take to solve the problem.
Kishore
India
    Hi Kishore,
    I am facing same issue. Did you get any solution for your problem?
    Krupesh
    yes, the period is same for design and simulation.
    regards
    kishore
    Hi, is the same period of your simulation clock and your designed clock?
    Wangm
