SWrig4
6 years agoHold time violations in ALTLVDS_RX with 300 MHz input clock
We are using ALTLVDS_RX to receive high-speed serial data in our design. We have been successfully using this design with 400 MHz input clock (800 Mbps) for a while. We are now trying to use the sam...
SWrig4
6 years agoWe have added input delay constraints as suggested in the user guide. The constraints are based around a 300 MHz DDR interface where the data and clock are center aligned.
Note that hold time violations are still present.
Please note that hold time violations are within ALTLVDS_RX IP.
We have also found that the hold time violations disappear if we modify constraints for 333 MHz clock instead of 300 MHz (see altlvds_rx_333.sdc).
Maybe there is a problem with specifying fractional clock periods?
