Liyen
2 years agoHLS compilation issues
Hello, I installed Quartus Lite 18.1 and came with HLS compiler 18, I tried to compile the QRD example but encountered following build errors, I think these are related to incompatible glibc v...
BoonBengT_Altera
Moderator
2 years agoHi @Liyen,
Good to know that you managed to run i++ now.
As for the modelsim issues, to check you have installed modelsim starter edition you mention?
And based on the error it seems like a missing files/library, and you mention you are able to find the required files and modify the path accordingly?
Does that help on fixing the issues?
Best Wishes
BB
