17 years agoHigh Speed Serial IO - Signal Loss Condition Resolution at the Bit Level
Hello, I have an application where each bit of data I send across the High Speed Serial IO Link (6Gbps) transceiver link is critical and knowing exactly where in my bit sequence (down to t...
17 years agoSome errors may be locatable down to the word level by the 88/10B decoder, others may be undetectable. You would need an additional error-detection layer (e. g. by CRC) to detect any error with a specified likelihood and optionally locate an error position.
