18 years agohigh speed pulse generation
I have an application in which I will be using a NIOS with some low speed logic ~30Mhz or so, but I also need to have a small part of my logic for generating high speed, high resolution pulse trains ...
18 years agoTo get 1ns resolution on pulse widths using timers or shift registers, I would need that chunk of logic to run at 1Ghz. This is beyond the capabilities of most mainstream programmable logic devices. On the other hand, I see that the serial tranceivers on some fpgas can exceed 1Gbps using internal PLLs. I only need to xmit fairly short pulse trains in a one-shot mode, but I do need to xmit two such pulse trains at the same time. I am considering using two of these serial tranceivers with long shift registers. If it works it could save adding an external pulse generator. Sound reasonable?
