11 years agohigh input voltage damage
I'm using altera de0 board cyclone III i put about 4 volts input to one or two of the I/O pins after that my laptop doesn't recognize the altera kit any more when it is connected. Did the 4 volts ...
11 years agoThe de0 user manual says
The DE0 board comes with a preloaded configuration bit stream to demonstrate some features of the board. This bit stream also allows users to see quickly if the board is working properly. All user LEDs are flashing All 7-segment displays are cycling through the numbers 0 to F My board still does this thing any help?
