16 years agoHigh currents at input pins
Hi All, I´m using a EPM 1270 TQFP. The problem is, that the part is drawing a lot of current at the input pins. All is working, but at my resistors I can see a high voltage drop. How can I act...
16 years agoWhat's "a lot of current"? Can you be more specific?
Unless weak pull-up resistors are activated, the inputs can be expected to show high impedance. If you observe something different, you probably assigned wrong pins.
