13 years agoHi, How to choose the speed grade in an FPGA or CPLD?
Hi I've a lot of questions about FPGAs and CPLDs speed grade, I want to generate a pulse of 3 ns acording to an event, which means that I need at least a 333 MHz clock, either external or u...
13 years agowhen you said "see" another pulse, you mean the output I want to generate?, and yes, I want to count, but in general what I want to to do is use an FPGA to replace a set of laboratory equipment that does the same thing (discriminator, logic unit), in order to compare, I have to generate the same output that the discriminator does
Thanks for the information, I'm going to read it, and I forgot to tell that the time between events is at least of 50 ns, and I have to study more about synchronous and asynchronous systems, because I believed that if my sampling method used or not a clock defined an synchronous or asynchronous system
