13 years agoHi, How to choose the speed grade in an FPGA or CPLD?
Hi I've a lot of questions about FPGAs and CPLDs speed grade, I want to generate a pulse of 3 ns acording to an event, which means that I need at least a 333 MHz clock, either external or u...
13 years ago --- Quote Start --- my input is a TTL signal: an aleatory pulse of 2.5 V amplitud and between 17 ns and 20 ns duration (the rising time is betwen 800 ps and 1 ns) --- Quote End --- Ok. --- Quote Start --- I care for events, when I see one, I have to generate an output with a 3.3 ns duration, the amplitud its not realy important it may be 3.3 V or 2.5 V. --- Quote End --- Why do you need to "see" another pulse? The FPGA could count the pulses if that is what you are interested in. --- Quote Start --- I was thinking in sample this input with a 300 MHz clock, (external or generated from pll) because is the duration I need for my output, and its enough for see the event. --- Quote End --- No, its not. Given that all you care about are events, you could use the pulse to toggle a signal internal to the FPGA. That toggle signal would stay at a logic high or low between events. Every time the toggle signal toggles is an 'event'. The clock frequency you need to detect events is then determined by the time *between* events, not the time of one pulse. Read this article here and you will understand what I am talking about http://www.edn.com/design/systems-design/4333702/crossing-the-abyss-asynchronous-signals-in-a-synchronous-world --- Quote Start --- It gives me the idea of working asynchronously --- Quote End --- If your pulses are not synchronous, then your system is already asynchronous. Cheers, Dave
