Hi guys I am writing code for shifting rows section in an AES algorithm stuck getting errors.
I am trying to create a matrix from a vector using for loops then mapping a matrix to move them to there required positions. but i keep getting the error Error (10028): Can't resolve multiple constant drivers for net "matrix1[15][4]" at sf.vhd(48)
This keeps occurring for all aspects of the array i have included a full script of the code. Thanks in advance. Ciaran.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity sf is
Generic ( DATA_LENGTH : integer := 128 );
Port ( data_out : out STD_LOGIC_VECTOR (DATA_LENGTH-1 downto 0);
finish : out STD_LOGIC;
data_in : in STD_LOGIC_VECTOR (DATA_LENGTH-1 downto 0);
start : in STD_LOGIC;
clock : in STD_LOGIC;
reset : in STD_LOGIC);
end sf;
architecture RTL of sf is
----------- TYPES -----------
TYPE matrix_index IS array (15 downto 0) OF std_logic_vector(7 downto 0);
---------- SIGNALS ----------
SIGNAL matrix1, matrix2 : matrix_index;
begin
-- Initialize and Reset process
reset_n_init_process : process(reset)
begin
if(rising_edge(reset)) then
for i in 15 downto 0 loop
matrix1(15-i) <= (others => '0');
matrix2(15-i) <= (others => '0');
end loop;
end if;
end process reset_n_init_process;
-- map the 128 bit input to matrix1 so we can shift it.
vector_to_matrix1: PROCESS(start)
BEGIN
if(rising_edge(start) and clock = '1') then
FOR i IN 15 downto 0 LOOP
matrix1(15-i) <= data_in(8*i+7 downto 8*i);
END LOOP;
end if;
END PROCESS vector_to_matrix1;
-- matrix2 is actually matrix1 shifted as shown in the above example.
-- combinatorial logic
-- first column
matrix2(0) <= matrix1(0);
matrix2(1) <= matrix1(5);
matrix2(2) <= matrix1(10);
matrix2(3) <= matrix1(15);
-- second column
matrix2(4) <= matrix1(4);
matrix2(5) <= matrix1(9);
matrix2(6) <= matrix1(14);
matrix2(7) <= matrix1(3);
-- third column
matrix2(8) <= matrix1(8);
matrix2(9) <= matrix1(13);
matrix2(10) <= matrix1(2);
matrix2(11) <= matrix1(7);
-- forth column
matrix2(12) <= matrix1(12);
matrix2(13) <= matrix1(1);
matrix2(14) <= matrix1(6);
matrix2(15) <= matrix1(11);
--map matrix2 back to 128 bit vector
matrix2_to_vector: PROCESS(matrix2)
BEGIN
if(clock = '1') then
data_out(8*i+7 DOWNTO 8*i) <= matrix2(15-i);
END LOOP;
finish <= '1';
end if;
END PROCESS matrix2_to_vector;
end RTL;
1 Reply
- sstrell
I think the problem is you have your reset and loading of matrix1 in two separate processes, causing multiple drivers into matrix1. The code should probably look like this:
process (reset, clock)
BEGIN
if(reset) then
end loop;
elsif (start and rising_edge(clock)) then
matrix1(15-i) <= data_in((8*i)+(7 downto (8*i)));
END LOOP;
else matrix1 <= matrix1;
end if;
end process;
#iwork4intel
