NKuma10
7 years agoHi All, I have some doubt regarding FPGA I/O banks.
I'm working on FPGA with I/O banks configured as 3.3-V LVCMOS with current strength of 2ma. I have a requirement to change the current strength to 16ma for some of the signals in this I/O bank which...
SreekumarR_G_Intel
7 years agoHello Andrew ,
Thank you giving opportunity to look at issue,
Can I assume few things from your input ,
i) You are not plan to use LVDS in the board using FPGA. Correct ?
ii) The VCCIO of bank 5 and 6 connected to the 3.3V. Also Can I assume VREFBx pin is not used for reference voltage ? Correct
If my above assumption yes , I don’t think so there is issue to connect the 3.3V bank 5 and bank 6 .
In the datasheet can you refer page 7 for the max apply VCCIO ?
Note : VCCA must connected to the 2.5V.
May I know why you think bank 5 and 6 need to use only for LVDS ?
Thank you,
Sree
