Helpless about 1588V2
HI Deshi and team
1. You mentioned you performed PHY_serial_loopback on port 1 but it somehow affect the transceiver status on port 0 ?
YES ,
PHY_serial_loopback on port 1 but it somehow affect the transceiver status on port 0;
PHY_serial_loopback on port 0 but it somehow affect the transceiver status on port 1;.
2. Or you need to perform PHY_serial_loopback on both port 0 and port 1 before you can get 1588 test run working ?
Before I can get 1588 test run working success , I need to perform "PHY_serial_loopback " “the Slave port”,and it is the only method to make 1588 test success 。Perform "PHY_serial_loopback " “the master port” without effect。
Hi Deshi and team
" Or somehow transceiver PHY reset controller IP is holding Rx channel in reset"
The Rx channel in reset , it is cause by the "rx_cal_busy=1", When the phy phy is being calibrated "rx_cal_busy=1" 。I so confused what is the matter cause the phy being calibarated
