mark_lee
5 years agoHelpless about 1588V2
I run the project "LL10G_1G_10G_LINESIDE_1588v2" on the demo board "Arria 10 SOC Development Kit"
1588V2 thranceive an receive are OK ; I made project run on my board(10AS066H3F34I2SG) , it is can...
Deshi_Intel
5 years agoHi,
- We don't support FPGA internal loopback from one transceiver channel to another transceiver channel. That's why you get design compilation error.
- We only support FPGA internal loopback within the same transceiver channel from Tx channel back to Rx channel
Just would like to follow up with you - did you have a chance to play around with different signal_tap triggering setup to observe different signal_tap result between passing and failing case ?
- Any latest debug update to share with me ?
dlim
mark_lee
5 years ago1. I had run the 1588 test project on my board with Optical fiber between 0 port and 1 port , when I run Signal Tap to get 0 port phy interface signal , I get an abnormal signal , the phy is being calibrated:
Under these circumstances,running 1588_TEST , Fail
2. Every time after running ”TEST_PHYSERIAL_LOOPBACK 1 10G 5000“ , The Signal Tap get an normal signal about 0 port phy interface :
Under these circumstances,running 1588_TEST , succes
