Helpless about 1588V2
Hi Deshi ant team
1. The Project "LL10G_1G_10G_LINESIDE_1588v2" is builded Reference the Intel Example "a10soc_322265325_Scalable_Eth1588_BUG2613_Quartus_16.1.0";
2. My Project is working on the Quartus Prime pro 19.2;
3.I have running my project on my board ,"TEST_SMA_LB 0 1 10G " is ok;
4.I have running my project on my board ,"TEST_PHYSERIA_LOOPBACK " is ok;
5.When finish TEST_PHYSERIAL_LOOPBACK , and running“TEST_1588 0 1 10G" right now,sometime frames received is good , "offset ns" and "delay ns" are good , but when runningTEST_1588 again it is receive annything 。
Hi Deshi ant team
In addition:
1. "TEST_SMA_LB 0 10 G 5000 " and "TEST_PHYSERIAL_LOOPBACK "1 10G 5000" are ok, message is :
(1)
% TEST_SMA_LB 0 10G 5000
CONFIGURE CHANNEL 0
configure_to_10G
setting up mac with a basic working config
setting 0xC5C4 into rxmac primary address Reg-1
setting 0xC3C2C1C0 into rxmac primary address Reg-0
enabling: pad and crc stripping in rx mac
testing Configure Period and Adjustment RX XGMII TSU
Configure Period and Adjustment TX XGMII TSU
clearing mac stats registers
Configure TOD Master
Configure TOD 10G
Disabling serial PMA Loopback (local)
Read back Serial PMA loopback register = 0x00000000
Select std ethernet traffic controller
Disable Avalon ST Loopback
B E G I N C O N F I G U R A T I O N
payload length = fixed ....
payload bytes = fixed incremental bytes ....
burst size = 5000 ....
payload length = 100 ....
frame source addres field = F0F1F2F3F4F5 ....
frame destination addres field = C5C4C3C2C1C0 ....
reseting monitor Packet Counters
number of Packets Expected By Monitor = 0x1388
burst being injected into device ....
-- MONITOR processing frames received .....
-- MONITOR Received Packet# 5000]
-- DONE! - monitor received all expected sum of packets .....
_________________________________________________________________________________________________________________________
-- (MONITOR) GOOD PKTS RECEIVED = 5000
-- (MONITOR) BAD PKTS RECEIVED = 0
-- (MONITOR) BYTES RECEIVED = 479992
-- (MONITOR) CYCLES USED = 75002
-- (MONITOR) THROUGHPUT CALCULATED = 8.00 Gbps
-- (MONITOR) RXBYTECNT_LO32 = 479992
-- (MONITOR) RXBYTECNT_HI32 = 0
-- (MONITOR) RXCYCLCNT_LO32 = 75002
-- (MONITOR) RXCYCLCNT_HI32 = 0
| MAC TX STATS REGISTER CHECK
|# FRAMES_RECEIVED_WITH_ERROR = 0
|# UNICAST_FRAMES_WITH_ERROR = 0
|# MULTICAST_FRAMES_RECEIVED_WITH_ERROR = 0
|# BRDCAST_FRAMES_WITH_ERROR = 0
|# FRAMES_RECEIVED_WITH_ONLY_CRCERROR = 0
|# VALID_LENGTH_FRAMES_WITH_CRC_ERROR = 0
|# JABBER_FRAMES = 0
|# FRAGMENTED_FRAMES = 0
|# INVALID_FRAMES_RECEIVED = 0
|# FRAMES_RECEIVED_GOOD = 5000
|# PAUSE_FRAMES_RECEIVED = 0
|# UNICAST_CONTROL_FRAMES = 0
|# MULTICAST_CONTROL_FRAMES = 0
|# UNICAST_FRAMES_RECEIVED_GOOD = 0
|# MULTICAST_FRAMES_RECEIVED_GOOD = 5000
|# BRDCAST_FRAMES_GOOD = 0
|# DATA_AND_PADDING_OCTETS_RECEIVED_GOOD= 410000
|# COMPREHENSICE_OCTETS_RECEIVED = 500000
|# FRAMES_WITH_SIZE_64_BYTES = 0
|# FRAMES_BETWEEN_SIZE_64AND127_BYTES = 5000
|# FRAMES_BETWEEN_SIZE_128AND255_BYTES = 0
|# FRAMES_BETWEEN_SIZE_256AND511_BYTES = 0
|# FRAMES_BETWEEN_SIZE_512AND1K_BYTES = 0
|# FRAMES_BETWEEN_SIZE_1KND1518_BYTES = 0
| MAC RX STATS REGISTER CHECK
|# JABBER_FRAMES = 0
|# FRAMES_BETWEEN_SIZE_ABOVE1519_BYTES = 0
(2)
% TEST_PHYSERIAL_LOOPBACK 1 10G 5000
CONFIGURE CHANNEL 1
configure_to_10G
Configure TOD 10G
Enabling serial PMA Loopback (local)
Read back Serial PMA loopback register = 0x00000001
|# JABBER_FRAMES = 0
|# JABBER_FRAMES = 0
- mark_lee5 years ago
Hi Deshi ant team
1. I do some test forward the step :
(1) "TEST_PHYSERIAL_LOOPBACK 1 10G 5000” ,is OK
(2) “TEST_1588 0 1 10G ” is OK
(3) "TEST_1588 0 1 10G" again, is not OK
2. The console system print message is :
CONFIGURE CHANNEL 1
configure_to_10G
Configure TOD 10G
-- MONITOR Received Packet# 5000]-- DONE! - monitor received all expected sum of packets .....
_________________________________________________________________________________________________________________________===================================================================
|# JABBER_FRAMES = 0
|# JABBER_FRAMES = 0
|# FRAMES_BETWEEN_SIZE_ABOVE1519_BYTES = 0% TEST_1588 0 1 10G
CONFIGURE CHANNEL 0 as master
configure_to_10G
Configure TOD 10G
CONFIGURE CHANNEL 1 as slave
configure_to_10G
Configure TOD 10G
Select 1588 traffic controller
Start TOD synchronization
Master 1588 start 1 step operation
TRAFFIC_CONTROLLER_BASE_ADDR: 0x100000
Waiting capturing offset delay ...
-- Break
Start capturing offset delay ...
Reset Master 1588 start 1 step operation
Reset Start TOD synchronization
delay ns = 0x00000030
delay fns = 0x00007197
offset ns = 0x00000000
offset fns = 0x00000000
|# JABBER_FRAMES = 0
|# FRAMES_RECEIVED_GOOD = 9120026
|# UNICAST_FRAMES_RECEIVED_GOOD = 9120026
|# MULTICAST_FRAMES_RECEIVED_GOOD = 0
|# DATA_AND_PADDING_OCTETS_RECEIVED_GOOD= 456001300
|# COMPREHENSICE_OCTETS_RECEIVED = 620161768
|# FRAMES_WITH_SIZE_64_BYTES = 4560013
|# FRAMES_BETWEEN_SIZE_64AND127_BYTES = 4560013
|# JABBER_FRAMES = 0
|# FRAMES_RECEIVED_GOOD = 4560013
|# UNICAST_FRAMES_RECEIVED_GOOD = 4560013
|# DATA_AND_PADDING_OCTETS_RECEIVED_GOOD= 209760598
|# COMPREHENSICE_OCTETS_RECEIVED = 291840832
|# FRAMES_BETWEEN_SIZE_64AND127_BYTES = 0
|# JABBER_FRAMES = 0
|# JABBER_FRAMES = 0
configure_to_10G
Configure TOD 10G
configure_to_10G
Configure TOD 10G
-- Break
|# JABBER_FRAMES = 0
|# FRAMES_RECEIVED_GOOD = 0
|# DATA_AND_PADDING_OCTETS_RECEIVED_GOOD= 0
|# COMPREHENSICE_OCTETS_RECEIVED = 0
|# JABBER_FRAMES = 0
|# JABBER_FRAMES = 0
|# JABBER_FRAMES = 0
