CosmoKramer
2 years agohelp with signal tap - copy and group
hello, i need help with two issues regarding signal taps. 1. i would like to copy a signal tap file instead of creating one from scratch. I tried to open it in text file and copy the parts I am in...
sstrell
2 years ago1) Why don't you just duplicate the file and then edit it? What's your goal?
2) More details needed. When does it work and when is it grayed out?
- CosmoKramer2 years ago
1) i want to copy signals between two instances within same signal tap file. i also want to copy "dividers", instead of right click and slect each time.
2) this happens randomly. it will be work fine for few times and then option becomes greyed out. there is no pattern. it is random.
- sstrell2 years ago
1) No way to do either of these that I know of.
2) You'll have to be more specific as to what you are selecting and trying to group. Screenshots would help.
