10 years agohelp with SDRAM
Hello
I need to load my code on SDRAM and run it but I don't know how to do it exactly (I already defined SDRAM on qsys) !! :( Help me with a clear tuto or doc about that ?! PS: using quartus 13.0 as well as nios ii web edition much appreciated !1 Reply
If you already have the sdram controller in your Nios-Qsys system, you simply need to link your code into sdram.
Open the bsp properties and set it in the linker options.
