Dayana
3 years agoHelp with running Intel High Level Synthesis Design Example on Windows
I am trying to run an Intel HLS Compiler design example on Windows by following the "Running an Intel® HLS Compiler Design Example (Windows)" guide.
I tried the "counter" and "QRD" examples ...
- 3 years ago
Thanks for your help Hareesh.
Just a summary:
- The error:
HLS Generate component ipxact for Platform Designer FAILED.
was solved by downloading and installing the Intel Arria 10 Device Support from https://www.intel.com/content/www/us/en/software-kit/706105/intel-quartus-prime-pro-edition-design-software-version-21-4-for-windows.html under the Individual Files, Devices section. - The error:
Error: Cosim testbench elaboration failed
# ** License Issue: License request for intelqsimstarter feature failed
# ** License Issue: Cannot checkout an uncounted license within a Windows Terminal Services guest session. (C:\flexlm\LR-118484_License.dat)
# ** Error: Failure to obtain a Verilog simulation license. Unable to checkout 'intelqsimstarter' license.
# ** Error: Error loading design
was solved by running the HLS test example on the local computer instead of remotely as I am using a fixed license and a floating license is needed for remote use.
- The error:
hareesh
3 years agoHi,
it's environment variable issue only. please follow bellow steps. after that also if you facing an issue please tell me your free time. I will arrange a call to guide you.
