14 years agoHelp with problem
Using the hierarchy design procedure and Quartus II software, design a digital code converter, which takes a 4-bit BCD input, and based on the value of the select bit the converter either generates t...
14 years agoIf you know the functions (derived from truth table) for bcd to excess3 and bcd to graycode, model the HDL designs using any of the 3 modelling techniques (gate level, dataflow, behavioral). Also model a 2:1 mux.
let the modules be 2_1mux.v , bcd2excess3.v and bcd2gray.v The following is my rough sketch of how the final design will be // module and port declaration //instantiations excess3.v (.input(bcd),.en(!s0),.ouput(excess3)) gray.v (.input(bcd),.en(s0),.ouput(gray)) 2_1mux.v (.data1(excess3),.data2(gray),.sel(s0),.output(output)) HTH..
