12 years agoHelp with modelsim
Hi guys! I'm having trouble simulating in modelsim. My code is below; library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; -- Begin entity declaration for "uppg...
12 years ago --- Quote Start --- Am I correct in saying that VGA_CLK is never assigned a value? Check your errors and warnings. There you may find something that may help you find the problem. --- Quote End --- Should I assign the value on the testbench? I can post the whole testbench and than maybe you can see were I went wrong. ---------------------------------------------------------------------------------------------------------------------------------------------- LIBRARY ieee; USE ieee.std_logic_1164.all; ENTITY test_vga_vhd_tst IS END test_vga_vhd_tst; ARCHITECTURE test_vga_arch OF test_vga_vhd_tst IS -- constants -- signals SIGNAL CLOCK_50 : STD_LOGIC := '0'; SIGNAL KEY : STD_LOGIC_VECTOR(2 DOWNTO 0); SIGNAL RESET_N : STD_LOGIC; SIGNAL VGA_B : STD_LOGIC_VECTOR(7 DOWNTO 0); SIGNAL VGA_BLANK_N : STD_LOGIC; SIGNAL VGA_CLK : STD_LOGIC; SIGNAL VGA_G : STD_LOGIC_VECTOR(7 DOWNTO 0); SIGNAL VGA_HS : STD_LOGIC; SIGNAL VGA_R : STD_LOGIC_VECTOR(7 DOWNTO 0); SIGNAL VGA_SYNC_N : STD_LOGIC; SIGNAL VGA_VS : STD_LOGIC; COMPONENT test_vga PORT ( CLOCK_50 : IN STD_LOGIC; KEY : IN STD_LOGIC_VECTOR(2 DOWNTO 0); RESET_N : IN STD_LOGIC; VGA_B : OUT STD_LOGIC_VECTOR(7 DOWNTO 0); VGA_BLANK_N : OUT STD_LOGIC; VGA_CLK : OUT STD_LOGIC; VGA_G : OUT STD_LOGIC_VECTOR(7 DOWNTO 0); VGA_HS : OUT STD_LOGIC; VGA_R : OUT STD_LOGIC_VECTOR(7 DOWNTO 0); VGA_SYNC_N : OUT STD_LOGIC; VGA_VS : OUT STD_LOGIC ); END COMPONENT; BEGIN i1 : test_vga PORT MAP ( -- list connections between master ports and signals CLOCK_50 => CLOCK_50, KEY => KEY, RESET_N => RESET_N, VGA_B => VGA_B, VGA_BLANK_N => VGA_BLANK_N, VGA_CLK => VGA_CLK, VGA_G => VGA_G, VGA_HS => VGA_HS, VGA_R => VGA_R, VGA_SYNC_N => VGA_SYNC_N, VGA_VS => VGA_VS ); CLOCK_50 <= not CLOCK_50 after 20 ns; RESET_N <= '0', '1' after 50 ns; init : PROCESS -- variable declarations BEGIN -- code that executes only once KEY <= "111"; wait for 50 ns; KEY <= "110"; wait for 50 ns; KEY <= "111"; wait for 50 ns; KEY <= "101"; wait for 50 ns; KEY <= "111"; wait for 50 ns; KEY <= "011"; wait for 50 ns; WAIT; END PROCESS init; always : PROCESS -- optional sensitivity list -- ( ) -- variable declarations BEGIN -- code executes for every event on sensitivity list WAIT; END PROCESS always; END test_vga_arch;
