14 years agoHelp with metastability problem
Hi, I'm working on a vision processing based project at uni using a custom board built around a cyclone III and I am having to modify some vhdl code written by previous years students. A met...
14 years agoIf you are doing a functional simulation (ie, just testing your code to make sure it works) clock speeds are mostly unimportant. I will generally just use a 100 MHz clock regardless of my final clock because it's easier to work out how many clock cycles have occured between two points when I put two cursers up.
BUT. If you have more than 1 clock in the system, it is very important to try and get the ratios of the two clocks as close to the real ratios as possible, to ensure data rates are correct and fifos etc dont overfill. If you are doing a gate level simulation, then yes, you need to use the real clock speeds, as this should point out any timing problems. But usually most problems are picked up at the functional stage after which you move into synthesis and timing analysis.
