14 years agoHelp with metastability problem
Hi, I'm working on a vision processing based project at uni using a custom board built around a cyclone III and I am having to modify some vhdl code written by previous years students. A met...
14 years agoAn other issue are the signals DVAL_IN, FVAL_IN and buffer_lock. If they are not synchronous to the clock you should/must synchronize them. Otherwise you will run into metastability problems with your fvalid_reg and lock_reg signal.
