14 years agoHelp with metastability problem
Hi, I'm working on a vision processing based project at uni using a custom board built around a cyclone III and I am having to modify some vhdl code written by previous years students. A met...
14 years agoTiming analysis is the way to find out about violations.
I see that you are trying to operate counters based on latches (in an asynchronous process). This can't work and Quartus will be surely issuing a number of warnings related to the construct.addr <= addr + 1;
count <= count + 1;
So there are apparently more basic problems than possible timing violations.
