14 years agohelp with code for pulse delay?
Hi, I am a beginner at VHDL coding . I require code such that when a "trigger " is input,the output is delayed for 10 clock cycles and then gives a 3 clock cycle high output and goes low again til...
14 years agoI recommend doing this in a state machine. A psuedo-code example is shown below, using VHDL 2008 and a record type for the counter signals of enable and done. Of course, you would have to code up the counter as another module, I've just shown the instantiation of the counter. Note the use of the record type making the signals associated with the counter a bit easier to follow. Best, James
--- Quote Start --- type stateType is (S0, S1, S2); signal state : stateType; type counterType is record done : std_logic; enable: std_logic; reset : std_logic; end record; signal counter : counterType; signal pulse : std_logic; signal dlyReg : std_logic_vector(2 downto 0); process(all) begin if RST then state <= IDLE; elsif rising_edge(CLK) then case state is when S0 => if Trigger then state <= S1; counter.enable <= '1'; else state <= S0; counter.enable <= '0'; end if; pulse <= '0'; when S1 => if counter.done then state <= S2; else state <= S1; end if; counter.enable <= '1'; pulse <= '0'; when S2 => pulse <= '1'; counter.enable <= '0'; state <= S0; end case; end if; end process; process(all) begin if RST then dlyReg <= (others => '0'); elsif rising_edge(CLK) then dlyReg(0) <= pulse; dlyReg(1) <= dlyReg(0); dlyReg(2) <= dlyReg(1); end if; end process; pulseOut <= dlyReg(0) OR dlyReg(1) OR dlyReg(2); /* ---------------------------------------- Delay counter instantiation ------------------------------------------*/ U3: entity work.DNCNT_INTEGER(BEH) generic map ( size => PARAM_COUNTS+1 ) port map ( CLK => MCLK, HRST => counter.reset, ENABLE => counter.enable, CNT_VALUE => PARAM_COUNTS, FLAG => counter.done ); --- Quote End ---
