13 years ago
Help using transceivers in HDMI-port on Arria V GX starter board to send TMDS data
I am working on a project where I want to send TMDS data to a monitor using the HDMI-port on my Arria V GX starter board. I have only limited experience form VHDL design and have also only worked with Xilinx before, and never transceivers.
I am using a Arria V GX starter board with a 5AGXFB3H4F35C4N FPGA and Quartus II 13.0.
For a couple of days I been trying without success to send something using the 1.5-VPCML transceivers.
What I want to achieve is to send 3 x 10bit that comes in parallel at 148.5Mhz using 3 transceiver lanes sending at 1485 Mbps. I also want to send the 148.5Mhz clock over a transceiver output.
Whether I am trying with one or more lanes I am stuck with these errors and critical warnings respectively:
Error (175020): Illegal constraint of Transmitter channel to the region (169, 11) to (169, 11): no valid locations in region
    Info (175028): The Transmitter channel name: hdmi_tx_p
    Error (175005): Could not find a location with: PMA_DIRECT_CHANNEL (1 location affected)
        Info (175029): Transmitter channel containing PIN_AJ3
    Info (175015): The I/O pad is constrained to the location PIN_AJ3 due to: User Location Constraints (PIN_AJ3)
Critical Warning: HSSI PMA TX Serializer port 'CLKDIVTX' on node PHYnat_Tx:Trans|altera_xcvr_native_av:phynat_tx_inst|av_xcvr_native:gen_native_inst.av_xcvr_native_insts.gen_bonded_group_native.av_xcvr_native_inst|av_pma:inst_av_pma|av_tx_pma:av_tx_pma|av_tx_pma_ch:tx_pma_insts.av_tx_pma_ch_inst|tx_pma_ch.tx_pma_ser should be connected
    Info: Must be connected
Critical Warning (11087): PMA direct channel(s) detected and needs to be constrained based on the guidelines in Arria V Device Handbook Volume 3: Transceiver chapter
Critical Warning (184043): Fitter was unable to find Transceiver Reconfiguration Controllers associated with the following 2 XCVR PHY IP component blocks
    Info (184044): Avalon Memory Map block PHYnat_Tx:Trans|altera_xcvr_native_av:phynat_tx_inst|av_xcvr_native:gen_native_inst.av_xcvr_native_insts.gen_bonded_group_native.av_xcvr_native_inst|av_xcvr_avmm:inst_av_xcvr_avmm|avmm_interface_insts.av_hssi_avmm_interface_inst
    Info (184044): Avalon Memory Map block PHYnat_Tx:Trans|altera_xcvr_native_av:phynat_tx_inst|av_xcvr_plls:gen_native_inst.av_xcvr_native_insts.gen_bonded_group_plls.gen_tx_plls.tx_plls|pll.avmm.av_hssi_avmm_interface_inst
And some additional warnings which I think are irrelevant.
I am using a Native PHY IP core in direct PMA mode and have assigned the pins the I/O standard 1.5-VPCML. What might be the problem? Am I on the completely wrong track?
Your help will be highly appreciated!
Aron
    Might it have to do with constraints that I need to define in a .sdc file? I know nothing about this and can't find anything in the handbook about ut. I also have "a new project" based on the golden top where I just use a native PHY and try to send something over a single channel. Still the same (relevant) errors and warnings though:
    Error (175020): Illegal constraint of pin to the region (169, 23) to (169, 23): no valid locations in region
        Info (175028): The pin name: hdmi_tx_clkout_p
        Error (184016): There were not enough differential output pin locations available (1 location affected)
            Info (175029): pin containing PIN_AC3
        Info (175015): The I/O pad is constrained to the location PIN_AC3 due to: User Location Constraints (PIN_AC3)
    Error (12289): An error occurred while applying the periphery constraints. Review the offending constraints and rerun the Fitter.
    Error (11802): Can't fit design in device
    You may need to test on one channel design first.
    so I suppose you havehdmi_tx_p [0], hdmi_tx_p [1], and hdmi_tx_p [2] since u have 3 channels right?
    --- Quote Start ---
    How is your 3 transceicer channels placed? It seems like the hdmi tx[0] is placed to invalid location. Do u refer to the referencen manual to set the pin assignment correctly?
    --- Quote End ---
    I am unable to check my design now but can take some screenshots tomorrow. But yes, I have the positive part according to the reference manual and set them to 1.5-V PCML. The software then adds the negative part automatically.
    I may also add that the error codes above are form a 1 lane test, but I get the same errors (but more) with more lanes.
