13 years agoHelp using transceivers in HDMI-port on Arria V GX starter board to send TMDS data
I am working on a project where I want to send TMDS data to a monitor using the HDMI-port on my Arria V GX starter board. I have only limited experience form VHDL design and have also only worked wit...
13 years ago --- Quote Start --- The error message does not seem related with SDC, but seem like the same pin is assigned to 2 location or fitter trying to merge two channel into same location. Do you have any special setting in the qsf? --- Quote End --- I am pretty sure that my assignments are correct. I have assigned the positive nodes and the software automatically assigns the negative nodes to the correct pins. I recently talked shortly to a friend and he also made me think that it might be something with how I declare the IP-cores in the .qsf. I have not done anything in the file at all, and the way that I have declared the IP-cores is like components and then "port map", is that wrong?
