17 years agoHelp RAM
hi, i am quite new to vhdl and quartus ii. i have coded a 16x8 ram using vhdl in quartus , and y need a ram of 256kb , when y chage the address_width to 131072, that is the number of bits that...
17 years agobut... what is the correct way to do it?
this is my code ... but something is wrong in it ... help me LIBRARY ieee; USE ieee.std_logic_1164.ALL; USE ieee.numeric_std.ALL; ENTITY Test IS GENERIC ( ADDRESS_WIDTH : integer := 131072; DATA_WIDTH : integer := 16 ); PORT ( clock : IN std_logic; data : IN std_logic_vector(DATA_WIDTH - 1 DOWNTO 0); write_address : IN std_logic_vector(ADDRESS_WIDTH - 1 DOWNTO 0); read_address : IN std_logic_vector(ADDRESS_WIDTH - 1 DOWNTO 0); we : IN std_logic; q : OUT std_logic_vector(DATA_WIDTH - 1 DOWNTO 0) ); END Test; ARCHITECTURE rtl OF Test IS TYPE RAM IS ARRAY(0 TO 2 ** ADDRESS_WIDTH - 1) OF std_logic_vector(DATA_WIDTH - 1 DOWNTO 0); SIGNAL ram_block : RAM; BEGIN PROCESS (clock) BEGIN IF (clock'event AND clock = '1') THEN IF (we = '1') THEN ram_block(to_integer(unsigned(write_address))) <= data; END IF; q <= ram_block(to_integer(unsigned(read_address))); END IF; END PROCESS; END rtl;
