14 years agohelp please......frequency divider
how to convert 25Mhz to 1hz,2hz till 10 hz....? and use level select to select the frequency..this is the detail: level 1-10 will select to frequency 1Hz to 10Hz.. i just can do till 1 Hz o...
14 years ago --- Quote Start --- if im using std_logic_vector type...how? generic(n: natural :=25); port( divCLK: in std_logic; level:in std_logic_vector (3 downto 0); Q: out std_logic); end countersystem; ---------------------------------------------------- architecture behv of countersystem is signal clkdiv: std_logic_vector(n-1 downto 0); begin process(divCLK) begin if rising_edge(divCLK) then clkdiv <= clkdiv + 1; end if; Q<=clkdiv(24); from this i can get 1Hz, but how to get 2Hz,3Hz and so on from these coding... is it Q<=clkdiv(23),Q<=clkdiv(22)...and so on? --- Quote End --- Something like this...not tested, but should get you nearly done. Homework assignment? use ieee.numeric_std.all; architecture rtl of countersystem is signal Q_int: std_ulogic; type arr_integer is array(natural range <>) of integer; constant CLK_FREQ: integer := 25000000; constant MAX_COUNTS: arr_integer(0 to 3) := (CLK_FREQ/2-1, CLK_FREQ/4-1, CLK_FREQ/6-1, CLK_FREQ/8-1); -- Constants for 1 Hz, 2 Hz, 3 Hz, 4 Hz...others left for the reader. This array will need to be expanded to be 0 to 15 to match the number of possible levels selectable by 'level'... signal Current_Count: natural range 0 to CLK_FREQ/2 begin process(divCLK) begin if rising_edge(divCLK) then if (Reset = '1') then -- You should add a reset to the entity Current_Count <= MAX_COUNTS(to_integer(unsigned(level))); Q_int <= '0'; if (Current_Count = 0) then Current_Count <= MAX_COUNTS(to_integer(unsigned(level))); Q_int <= not(Q_int); else Current_Count <= Current_Count - 1; end if; end if; end process; Q <= Q_int; end rtl; Simulate and test first. Kevin Jennings
