Help on understanding HDL module "always" clock transitions
- 2 years ago
it's the design concept.
The condition if( xcount2[10:0] == 11'd433 ) can't produce constant frequency, evenly spaced events when applied to the 15 bit baud rate counter.
You can however easily achieve waht you want by slightly rearrangind the design:1. have a 115k2 tic counter producing you constant frequency tic.
2. divide the 115k2 tic down according to select baud rate, fortunately they involve integer frequency ratios.
Your time constants are 1 clock period off, by the way.
