15 years agoHelp needed for this 3 bit parity generator/checker.
:cry: Im a total Noob and seriously need help in my VHDL. the question: To design a 3-bit parity generator/checker that has three data inputs (A to C) and two odd/even parity outputs (odd_o...
15 years ago --- Quote Start --- There is a signal inside the architecture because the even_out signal is the complementary of the odd_out signal but you cannot read an output, so you cannot write directly : even_out <= not odd_even. --- Quote End --- It is not simply the inverse, because if all A,B and C are '0', then odd and even out are '0'. The state table is very similar to a full adder, with even out being Sum and odd out_out being carry, but the A, B, C = '1' case makes it different.
