18 years ago
Help Needed: Ch7010 Tv output
Hi All,
Has anyone tried to configure the ch7010 chrontel chip for TV output mode. My system has 640x480 resolution video output in VGA mode.
But i want the output in composite video / S-video format. I am using altera 3c120 development board and for the input / output video, I am using Bitec Quad video board.
And the CH7010 chrontel chip need to be configured for TV output. I tried configuring the chip for both slave clock mode as well as master clock mode.
But in both the modes, the output video quality is pathetic with a lot of "dot-crawl effect" and mixing of chroma / luma bandwidths.
I tried setting different bandwidth settings for chroma / luma filters but have no effect on output.
Can anyone please suggest the directions to solve this problem.
The active output video resolution need to be 640 x 480. the TV output format can be anything NTSC / PAL.
Thanks in advance.
Foram
    Sorry for the delayed response.
    here are the ch7010 settings for VGA output. These settings are for the VGA resolution output 640x480 from the DVI port.
    i2c_write(base_address, 0xea>>1, 0x15, 0x00 );
    i2c_write(base_address, 0xea>>1, 0x31, 0x00 ); //
    i2c_write(base_address, 0xea>>1, 0x32, 0x23 ); //
    i2c_write(base_address, 0xea>>1, 0x33, 0x08 ); //
    i2c_write(base_address, 0xea>>1, 0x34, 0x16 ); //
    i2c_write(base_address, 0xea>>1, 0x35, 0x30 ); // chrontel
    i2c_write(base_address, 0xea>>1, 0x36, 0x60 ); //
    i2c_write(base_address, 0xea>>1, 0x37, 0x00 ); //
    i2c_write(base_address, 0xea>>1, 0x49, 0xc0 ); // Set DVI MODE
    i2c_write(base_address, 0xea>>1, 0x21, 0x01 | 0x08 ); // DAC bypass
    i2c_write(base_address, 0xea>>1, 0x22, 0x16 ); // BCO = VSYNC
    i2c_write(base_address, 0xea>>1, 0x1c, 0x04 ); // Invert XCLK Polarity
    Hope this would help.
    I am attempting this right now and having little luck.
    Amazingly enough, I can actually see a [mangled] image when using the Bitec reference design, which supposedly outputs to a different VGA board!
    When I attempt to configure the Ch7010b using the documented settings I get nothing. Any project or code showing register settings that achieves this would be greatly appreciated.
    William Guynes
