14 years agohelp me please
i'm a student working for the first time with altera DE2 board .i'm using the NIOSII soft processor with the altera monitor program (using C language)
i've some troubles with the program i wrote.i'm creating a dynamique list (ie using pointers) and at each time i creat a an element i display it in the seven segment display (i used the seven segment inorder to check if the elements of the dynamique list are created ) .the problem is that the program is not working (nothing is displayed ) so can you PLEASE help me and tell me what's wrong. here is the program: # include <stdio.h># include <stdlib.h># define HEX_BASE_ADDRESS 0x00021000# define SWITCHES_BASE_ADDRESS 0x00021010 /*__________________________~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ creat a node that enable us to work with the linked list */ struct node { int info; struct node *link; }; typedef struct node *NODE; /*_________________________________________________________ get node */ NODE getnode() { NODE x; x = (NODE)malloc(sizeof(struct node)); return x; } /*_______________________________________________________ insertion of an available place in the linked list */ NODE SortedInsert (int num,struct node**headRef) { NODE newNode; newNode = getnode(); newNode->info = num; newNode->link = NULL; struct node *prev, *curr = *headRef; if (*headRef == NULL || newNode-> info <= (*headRef) -> info) { newNode -> link = *headRef; *headRef = newNode; return newNode; } else { while (curr && curr -> info <= newNode -> info) { prev = curr; curr = curr -> link; } prev -> link = newNode; newNode -> link = curr; return *headRef; } } /*---------------------------------------*/ int get_hex (int NO) { int hexd; if (NO==0x01) { return hexd=0x79; } else if (NO==0x02) { return hexd=0x24; } else if (NO==0x03) { return hexd=0x30; } else if (NO==0x04) { return hexd=0x19; } else if (NO==0x05) { return hexd=0x12; } else if (NO==0x06) { return hexd=0x02; } else return hexd=0x40; } /*-------------------------------------*/ int main() { volatile int * switches = (int *) SWITCHES_BASE_ADDRESS; int * hex=(int*) HEX_BASE_ADDRESS; int num,NO,delay_count;//HEX_bit1; NODE list1=NULL; NODE temp; while(1) { //printf("enter the code"); //scanf("%d",&num); num= *(switches); list1=SortedInsert(num,&list1); if(list1 == NULL) { //printf("List is empty\n"); *(hex)=0x06;//display E } printf("The contents of the queue are\n"); temp=list1; while(temp!=NULL) { NO=temp->info; // printf("%d",NO); *(hex)= get_hex (NO); temp = temp->link; for (delay_count = 5000000; delay_count != 0; --delay_count); } } }2 Replies
Have you succeed ?
Have you checked your displaying on seven segments only ?
For displaying, I expected printf() or IOWR... or user function. your# define hex_base_address 0x00021000 may be wrong : it depends of your generated SOPC (I think you are using Altera example for DE2 board). In system.h (generated by sopc builder for quartus version <= 9.1) (or equivalent) you should look at, there are already# DEFINE for hardware. You should use IO_WR... functions : I think it takes care of wait time, delay, time hold... (I am not sure at 100%) Printf() your "list1" so as to see its value. The same "list1" doesn't change within you superloop (while(1))++
