17 years agoHelp me in translation of VHDL to verilog
Hello! How can i convert a two-dimentional output & input port of vhdl into a verilog. vhdl: type VARIABLEARRAY is array (1 to NBRVARIBLE_CT+10 ) of SLV32; ----------------------------...
17 years agoIn case you don't really need a bidirectional wire but have declared this signal as inout because of the VHDL readback restrictions then you just can declare the signal as reg in Verilog.
