18 years agoHelp: HSMC and I2C
I am having a hell of a time trying to interface a camera through an HSMC - Santa Cruz adapter board (THDB-H2S - http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=39&no=21...
18 years agoWeak pull-ups are definitely too weak for regular I2C speed at some load capacitance. They can't be set to a higher strength. You should use external resistors of 1K to 4.7K maximum. As said, for SCL a push-pull driver can be used instead for most I2C applications, so basically an approriate SDA pull-up is what you need urgently.
