18 years agoHelp: HSMC and I2C
I am having a hell of a time trying to interface a camera through an HSMC - Santa Cruz adapter board (THDB-H2S - http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=39&no=21...
18 years agoWith weak pull-up, SDA and SCL rise time may be too slow. You can slow down the I2C master timing in this case or use external strong pull-ups. They should me connected to 3.3V VCC to achieve a higher level without level translation. SCL could also use a push-pull driver, if no clock stretching is implemented by the slave. (Most likely it is neither used by the slave nor supported by the master).
