16 years agoHELP!! HOW TO WIRE 2 .vhd FILES!!!! IN QUARTUS!
Hey everybody I have designed my own microprocessor (upro.vhd) in VHDL and my own(proper) memory(report) RAM of 256x4bits with QUARTUS II 9.0 (ram256x4.vhd), but I have a problem, I need ...
16 years agoHello,
If I understood, what you have to do is to instantiate your memory from the top file. You can do it in this way: entity upro is port ( clk: in std_logic; Rst: in std_logic; R_w: out std_logic; dir: out std_logic_vector (7 downto 0); dat: inout std_logic_vector (3 downto 0) ); end upro; . . . signal a: std_logic_vector(3 downto 0); signal carga_a: std_logic_vector(3 downto 0); signal pc: std_logic_vector(7 downto 0); signal carga_pc: std_logic_vector(7 downto 0); signal rdat_in: std_logic_vector(3 downto 0); signal dat_in: std_logic_vector(3 downto 0); signal dat_out: std_logic_vector(3 downto 0); signal rwaux: std_logic; signal presente: estado:= inicial; COMPONENT ram256x4 is port ( Clock: in std_logic; OE: in std_logic; RW: in std_logic; CS: in std_logic; RW_Addr: in std_logic_vector (7 downto 0); Data_A: inout std_logic_vector (3 downto 0); Data_B: in std_logic_vector (3 downto 0); ) END COMPONENT; ARCHITECTURE ... BEGIN TEST_ram256x4 : ram256x4 port map ( Clock=>Clk, RW_Addr=>dir, DATA_A =>dat, RW=>r_w, ... ); ... Hope it helps you DABG
