15 years ago
help for driving ccd imgae sensor with 5v output
Thanks for reply.
i want to design ccd image acquisition system.In my
design ,i took Kodak KAI-1020 sensor and altera
cycloneii FPGA. cycloneii fpga produces ccd drive
signals. But problems is the driving timing signal
level is +5 v and the cyclone II io output singal level is 3.3v.
i want to insert a buffer(74ac04) between the FPGA and the CCD.
In the kai-1020 handbook,it use 74a04 as a buffer .But the reference design it use lattice isp1032e(cpld) chip.
Based on the following considerations,i took the 74ac04 as the buffer between the FPGA and the KAI-1020 sensor. is it wrong?
Sheng Li
detail information about ccd drive singal level and 74ac04 key information
1.Pulse Amplitudes -ccd drive signal 
Clock Min. Amplitude (volts) Coupling Min. Coupling Capacitor Value (µF) Max. Coupling Capacitor Value (µF)
SH 3.5 DC -- --
H1 4.7 AC 0.1 0.47
H2 4.7 AC 0.1 0.47
SA 4.7 AC 0.01 0.47
SB 4.7 AC 0.01 0.47
R 4.7 AC 0.01 0.47
T 4.7 AC 0.01 0.47
V1 4.0 AC 0.01 0.47
V2A 4.0 AC 0.01 0.47
V2B 4.0 AC 0.01 0.47
FD 4.0 AC 0.1 0.47
2. 74ac04-buffer
Vcc +5v
High Level Input Voltage 2.75v
Low Level Input Voltage 1.65v
High Level Output voltage 4.86v
Low Level Output voltage 0.36v
    --- Quote Start ---
    The FPGA cannot provide a 5V drive signal, you will need to insert a buffer between the FPGA and the CCD.
    --- Quote End ---
    thanks for your reply .In the kai-1020 handbook,it use 74a04 as a buffer .But the reference design it use lattice isp1032e chip.
    ccd drive signal level ,
    Sheng Li
    file:///C:/Documents%20and%20Settings/admin/Application%20Data/Tencent/Users/408645743/QQ/WinTemp/RichOle/0IF21UZOR6~NVM%7DBA01S1DK.jpg
