15 years agoHelp for counter programme
Design a 4-bit up/down counter with synchronous counting and asynchronous master reset. Write a VHDL design description of the counter based on the following criteria: a) The counter in...
15 years agothis is what i have so far .
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity mini is port ( en, m_reset, UP_DW, clk : in std_logic; q : out std_logic_vector (3 downto 0)); end mini; architecture flow of mini is signal count_sig :unsigned (3 downto 0); begin process ( en, m_reset, UP_DW, clk ) begin if (en = '1' and m_reset = '1') then count_sig <= "0000"; elsif(en = '0' and m_reset = '1') then count_sig <="0000"; elsif falling_edge (clk) and UP_DW = '0' then count_sig <= count_sig +1; elsif falling_edge (clk) and UP_DW = '1' then count_sig <= count_sig -1; end if; end process; q <= std_logic_vector (count_sig); end flow; how to make the altera board show hex from " A to F " ??
