18 years agohelp: data read from not same as the *.flash file,why?
hi, i downloaded the *.flash into flash, and run the program successfully, i read the data from ext_flash in nios program, and found it's not the same as the *.flash i used, why?
18 years agoThis is because the .flash file is an s-record, which is different than the binary format you would read from the flash chip.
S-records contain additional information about the data, such as where to put it in memory.
